spook302
- 169
- Aug 17, 2009
Durango,
Colorado
So here it is. Wen I start the car in the morning the tach stays at zero. 15 minutes into my morning drive it start to work but reads too high and sometimes stays high while at idle. Ill get to work turn the car off and work for three hours and take a lunch. When I go to lunch it works fine, for the rest of the day it will work just fine. Then the next morning zero again till later. Why? I first thought something under the hood could be affected by heat. Like it doesnt work till its warm. That is not the case. i let it warm up fully this morning before driving it and still nothing. I checked the wire connect at the coil pack, its fine. The connection at the module is fine as well. None of the other gauges are affected just the tach. Any advice would be great. I would really like to resolve this problem as it is the last real problem since I rebuilt the car. i dont know if this was a problem since I rebuilt the engine cause i bought the car with a slipped belt and bent valves
