Camber
2g4G63
Jan 16, 2004
Corona, California
i have a very small gap in between the top of my rear tires and the top of my fender which was a result of lowering my car. Im worried that if i install a camber kit that the fender will sit on top of my tire. should i just get an alignment and keep the camber because i dont know what i can do. thanks
[broken-record mode]
Camber is not what eats tires. It's toe that eats tires. Yes, camber plus toe eats tires faster than toe alone, but camber alone does no damage.
[/broken-record mode]
Spec on a DSM calls for rear toe in. Have the car aligned with zero toe front and rear and you can run 2.5 degrees of camber. Not all shops will do this. Make sure that they will before handing over the car ... or, better yet, find a place that will let you help to do it.
- Jtoby
So if the inside of my tires is wearing much faster then the outside, toe is the problem?
