Idea for SPL Coilover Setup
Turbo Shogun
260
Nov 23, 2003
Bolingbrook/Chi, Illinois
Browsing across Ebay, I found these...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33582&item=2450116613
It's cheap, but I'm thinking ditch the springs that come with those and replace them with these...
http://www.hopupracing.com/tasuprrasp.html
So you get the perches to adjust ride height and get better springs.
Perches are just perches right?
I plan on getting KYB AGX's or Koni adjustables as well to pair them up with. Will these work? Any suggestions? Thanks.
BTW, I searched for a thread like this, and didn't find any. Thus, I took the liberty to post one myself.
I dont see a reason why they would not work. Also I have agx's and I love them. For advice :)
From what I know, a 1g would do best with Koni fronts and AGX rears. The Koni's are shortened in front and externally adjustable on the car, while the rears must be taken off to be adjusted (which means basically non adjustable in my opinion). So you don't want the rear Yellows. Suspension travel isn't as limited in the rear so the AGX's will work just fine AND can be adjusted on the car. It'll make for a stiff ride back there though. If you buy them at AMS the set will cost $540.00 for front Koni's and rear AGX's.
that link doennt bring you to the spring page, those coil overs are real cheap, but do they work on an AWD? alos could you send a link to the springs? and are you sure that they will fit on them coil overs?
99% of all coil-over kits use 2.5" springs. These are different from any springs that are made for use without a coil-over kit. The best 2.5" springs are HyperCoils, but Eibach Race Springs are good enough for anyone reading (or writing) this.
- Jtoby
