PaulPDX
- 884
- 2
- Oct 11, 2003
LA,
California
First off, I don't want this to be a pissing fest. I'd like to see a good informative discussion with good scientific substance so that anyone who has questions about the subject can make their own educated decisions.
Personally, I've heard may times about how cross drilled rotors can crack, which I think is an over-exaggerated myth... anything poorly made will break under stress. I've also heard numerous times that slotted rotors are THE only way to go.
However, if slotted rotors were indeed the only way to go then why are Porsche factory rotors cross drilled rather than slotted? This leads me to wonder if the above state ment about slotted rotors is just another over-exaggerated, over-regurgitated myth (like synthetic lube will wreck your gaskets... ridiculous).
Perhaps for track use, slotted rotors are the only way to go... but on a street car or a car that spends 80 to 100% of its life on the streets... perhaps slotted rotors aren't neccessary.
Your thoughts?
Your thoughts?
. So true. I've noticed the same trait too... even amongst the 2G owners. Wonder why that is... the 2G turbos aren't exactly cheap compared to other cars of the same class (price and market segment... not in terms of performance).
