What is the best rear camber kit
ProjectAWDeagle
86
Sep 24, 2003
Hello
what is the best rear camber kit for a 1G AWD talon? I would like it to be around $50US... I am looking at the front Eibach camber kits. Any help would be great..
Thanks, Mike :talon:
Here are the options I know of. The commercially-produced items each seem to have their
own unique little drawbacks.
Whiteline makes bushings with a metal eccentric insert. http://www.whiteline.com.au/
It's made for Galant VR4, but also fits any 1G. This is what I used. One thing to be aware of is that when
someone is doing the alignment, the insert can jam up and they'll need to know to disassemble/reassemble
the bushing to free it up.
Ingalls makes an adjustable upper control arm. http://www.ingallseng.com/parts/3842.htm
I know of some people where this arm has gotten bent from hitting a curb or something.
Other alternatives are changing the arm lengths by cutting/welding like in the VFAQ,
or a bolt-in insert from http://www.taboospeedshop.com/
I have the TSS rear camber kit...no complaints whatsoever. It fixes camber AND stiffens up the upper control arm. The install involves cutting and drilling your upper control arms, and if you don't mind it, this is the kit for you.
