Ball Joints HELP!
95EclipseGSX
34
Dec 12, 2002
I have a 95 GSX eclipse, and I cant get the damn Upper ball joint (front) shaft to stop spinning (I'm trieing to tighten the bolt). It seems as though I need something to hold the shaft still so I can tighten the bolt. Help How Does This Thing Work??? :dsm:
Take a nut off another ball joint and use it to tighten it down. Sometimes the plastic ont he lock nut doesn't cut on a shaft and causes it to spin. See if that helps.
Thanks for your help. I figured it out I just had to lower the car and than tighten the bolts, the pressure from the car pushed the shaft down.
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
  • For sale 420A 420a valve covers
    $40 + shipping / OEM Black 420a valve cover $100 + shipping / Powder coated candy red Valve...
    • Stizzydrew
  • Wanted 1g GSC S2 cams
    Looking for a set of good condition GSC S2’s.
    • I21chardh
