Twisted Talon
- 68
- Oct 4, 2002
I do alot of showing with my car, and Im looking for somthing that will put my car down far...but not airbags..no thanks. I have a ground control set up now which slams the rear really good, but I want the front down farther. So I will be getting some true coilovers here before spring but I need to know which will slam me. Pics and set ups would be great. anyhelp???
Thanks
Aaron
Thanks
Aaron
You do not need new coil-overs. If you are all the way at the bottom of the sleeve on your GCs, then just buy shorter springs, too, or get GC upper plates (if you don't have them already), since these will get you another 3/4" of travel. GC can swap the little black rings inside the sleeves for ones that fit Konis. You have to do this, too, because Konis need a different sleeve support from all other shocks.
