Tein coilovers
-I'm using the C/O from DiamondStarSpecialties with AGX, the DSS kit require the removal of the front strut spring perch(grinder), 375 lbs front and 350 lbs rear for the springs. I'm sure Ground Control also make some, but if you want some serious set-up, check out JIC's.
