GreddySpyder
- 414
- Oct 21, 2002
Alabama
I get a shake in my steering wheel when cruising down the highway, but ONLY between 45-50mph, it isn't a really bad shake, but I can tell it is there. I also get a bad shake through the steering wheel when I hit the brakes at higher speeds (about 70+mph). Back when this first started I thought i must have warped rotors or something, but I have replaced all 4 rotors and brake pad sets and it still does the exact same thing. I can hit the brakes below 70mph and I don't even get the slightest hint of a shake, but above that it will shake the steering wheel like crazy. I have a CV joint that will pop every once in a while when my steering wheel is turned sharply to one side or the other, but would a CV joint going bad cause a problem like this? Any ideas of what the prob could be?
