my95tsi
- 926
- Dec 6, 2002
Chicago,
Illinois
Ok i got an alignment done at ntb. I put my front and rear camber kit in but it only adjusts +/- 1 degree. Oh by the way i have h&r sport springs w/ 1.7 drop in the front and 1.4 in the rear. The rear is completely set to spec. The toe is fine in the front but only the front left tire is in spec for camber. My right front is negative 2.3 which is much different than my front right which is 0.6. They maxed out the camber kit on the right and its still way off. But i leave for school on a 250 mile roadtrip in a week so i won't be able to fix it yet. Atleast my toe is in spec and the front right is closer than it used to be which was 3.3 for camber. Will it be ok to drive down to school for 250 miles with the camber off on this one tire? I had my suspension on for over a month with no cmaber kit and saw no tire wear yet. Also in the near future when i get the extreme camber kit can i just put it on the front right to get it into spec? Oh and by the way my car doesn't seem tro pull at all in any direction.
