after lowering - creaking noise
thefirstone
Jul 17, 2002
San Mateo, California
I lowered my car 2 in with goldline springs. I used stock stuff for the rest of the install. Now I get a creaking noise and poping sound sometimes when the car goes over bumps and stuff like that. I know the springs will be loose since they are shorter so I tac welded one to the strut to see it that would solve it. Didn't work still got it. Is it the ball joints?
Tim
The welds can be broken. Yes I am using the stock struts. Yes I do have everything tighten down and I have checked it three times now. One thing I did notice is since I have lowered it I cannot get my jack under the middle of the frame anymore so I use a smaller jack which I put under the frame connection just in front of the tire to get it started. Their is some sort of bushing their connecting the frames together. When I was lifting it it made the creaking noise I hear on the road, any connections their, can I lubricate it to sop the noise. I am thinking also if it is the strut I can tap more threads on the shock bolt so I can tighten the nut down more.
Tim
Show me a pic of this bushing you speak of...
Also get rid of the stock struts. They WILL NOT last long if they are not alsready gone.
And NO , you do not have to tap the threads more. There is NO reason to do that. These things are designed to have a specific travel.
Also did you trim your bump stops in accordance with what the manufacturer said for your springs?
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
