Axle stuck in hub
Church
123
Jun 12, 2002
New Jersey
Ok this is a huge pain in the a$$. Passenger side axle came out no problem, driver sides a totally dif story. Had to heat the nut and use an impact gun we use to take lugs off my dads tractor/trailers. Then the real fun began, we beat the axle nut to pieces trying to pound the axle out of the hub with a sledge hammer, then mushroomed the axle, burned the mushroom off then put the whole knuckle, hub and axle on a press and snapped the knuckle. This was about 4 hours of heating and beating on this dam axle!
My question is should i get these part from a junkyard or mitsu, i was planning on gettin the knuckle from the junkyard and the hub assembly from mitsu.
Or would it be better to just get the hub assembly from the junkyard as well and replace the bearings myself. Im trying to save money here but if the hub assembly is'nt to much from mitsu id rather get it new.
I had that same problem with both my front axles. I have an rs though, but anyways ...... I ended up pressing and heating them at the same time. When I say PRESSING, I mean 14 ton hydraulic jack used as a press. My bearings were fried, replaced both hubs. The wheel bearing for my car only came as an hub assembly, I think they were around $200 each! And both axles replaced. But your car might be different good luck.
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
