de_shadows
- Apr 19, 2003
i recently replace my brakes and need to take out my rotors for grinding. how do i take out my two front rotors?... i need help (98 gst)
i need some help here people!
god can somebody help me here....?
Originally posted by MNGSX
Crack lugs nuts loose with tires on the ground.
Then put on stands.
Remove wheels.
Remove brake caliper mounting bolts.
Hang caliper with rope or stiff wire hanger so the caliper is'nt just hanging by the hose.
Run a lug nut on until its 1/4 to 1/2 from the rotor. This keeps it from shooting off and rolling around the shop.
Use put a piece of 2x4 or something against the back of the rotor if you are using them again.
Now smack the caliper from behind with a good sized hammer with the wood as a buffer between the two.
Rotate the rotor around and smack. It should eventually pop loose. If not PB blaster it and hit a touch harder.
If you aren't turning them just omit the board and smack that focker.
