ground controls
TRUSTEDONE2003
96
Jan 14, 2003
vancouver, Washington
i have ground controls with the perches all the way down and it only drops the car about an inch. i want the tires to sit right at the wheelwells so does anybody know a shorter spring i can get that will fit on with my coilovers?? the springs i have are eibach. thanx......trust
I woulnd't recommend putting some other springs on it..if you want it lower I would just cut a coil or 2 off your current springs..but i wouldn't recommend that either but its cheap and will work fine still..
if its only dropping the car an inch you or whoever installed them messed up.
nah, don't think so bro. the springs are just too big. like i said the perches are all the way down. and i've read the instructions on installation that is on 2gnt. it's not like it's difficult to do. i really don't want to cut them either. i'll keep these for winter time but i want to slam it for summer, ya know??
i haven't checked that out yet. honestly i didn't even consider that possibility. i bought it with them already on so i haven't pulled the rear tires off yet. i read in a mag that these only lower 1inch to 1.5inch drop,
so i thought it was normal for these. i'll check it when i get home. thanx bro
