A. Van
- 346
- Jul 1, 2002
OK. I just got my Ground Controls, Koni's, Sway Bars, Bushing kit, Baers, AEM's, 18X8 with 225/40 tires, and about a 2 inch drop.
When I take a hard turn, I get a rubbing noise. It sounds like it's coming from the rears and there is a bit of a clean ring around the the tire on the inside. I think I'm rubbing on the arm that goes over the tire. I lefted the rear to see if it helped and it did a little.
Would spacers and/or a camber kit help. I'm thinking it will fix the problem, but I wanted to get all your advice on it. Maybe I should firm up my koni's somemore?
Thanks
Thanks
