Drew84
Supporting Member
- 31
- 1
- Jan 30, 2003
Peabody,
Massachusetts
Ok I have 90 tsi awd I want to go autocrossing with it so I need some need wheels. The stock ones have had it. They're very weak. I've decided on Rota Subzeros because they are a great compromise wheel between price and light weight. For $100 less than Supperleggars they weigh 16 pounds and for almost $200 come in as many colors as TE37s. These are the 17, 7.5 wheels. My guestion is I know the right bolt pattern but what is the correct offset? Is it 45mm or 48mm? According to MachV, who dosen't give you the offset of the wheels, you need a 3mm spacer on the front so that the CV axel nut clears the center cap if you want it on the wheel. If I went with a 48mm would I avoid this problem?
