springs & shocks?
erc's_gsx
292
Mar 25, 2003
is it recommended that i get shocks with an eibach pro kit springs or is it just a better thing to do just for the sake of my car?
both. You might be ok for a while with those springs, but for the sake of your car and suspension overall just spend the extra cash and get some struts, you be happy you did. at least i was...
struts our what most cars use...it has a coil that goes over it or "spring"...and a shock is easiest explained as go look at a lifted truck...what do you see just a big ol white and red lookin thingy that probly says rancho...that is a shock it does need have a spring that goes around it... its kinda the same idea as a bicycle that has front shocks on it...thats a shock not a strut...i think i just confused myself but oh well.....haha
yea please explain, you confused the hell outta me, i am in the process of lowering my car too, dont knw what to get.. if i get springs and struts will my stock shocks be fine?
ok, this is way off. a strut is where the spring and shock are one assembly. A car that uses simply shocks has a spring that is seperrate.
so in essance, we have a spring and a shock, but together they are known as a strut.
get new shock when you buy the springs. The stcok shocks well not last long and wil create more problems.
Do a lot of research wehn lowering a car. I would suggest if you do. You buy new shock, and camber kits from BOTH front and rear.
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
  • For sale 420A 420a valve covers
    $40 + shipping / OEM Black 420a valve cover $100 + shipping / Powder coated candy red Valve...
    • Stizzydrew
  • Wanted 1g GSC S2 cams
    Looking for a set of good condition GSC S2’s.
    • I21chardh
