BadAss4Bangers
- 88
- 3
- Feb 10, 2012
meriden,
Connecticut
So the previous owner installed the GC Coilover conversion kit for his Koni Yellows.
I am a little dumb founded when it comes to suspension but would I be able to take the springs off the GC kit and just install them on the Koni's or do I need additional parts/hardware?
Here is why I am getting rid of them....
I emailed GC and this is what they said went wrong.
" The damage is due to undertightening of the Koni Jamnuts. The bushings require a small amount of pre-load when installed to prevent them from unseating from the bore."
Edit: I just spoke with GC and they said all I need are those bushings and I should be all set so they are sending me a set to replace them. I will continue to use the GC sleeves and try to reassemble them correctly.
