loudawg
- Dec 1, 2002
Hi all. I got some Powerstop slotted/cross drilled rotors with Axxis pads a couple of weeks ago, and I love them. However, I noticed that I can't even lock up my wheels anymore if I tried. I'm afraid that I may not be getting the full braking capacity out of my system, and in an emergency situation, that might be BAD! Powerstop recommends you use DOT 4 brake fluid, and I'm not sure what my 98 Eclipse GS came with, but I would think probably DOT 3. Is DOT 4 really that much better? I'm assuming it's just more dense, reducing the "sloppiness" or "mushiness" in the braking, and putting more force on the brakes before the pedal hits the floor. Also, I heard there is a DOT 5 fluid out. The cap says DOT3 or DOT4.
So my first question is. Does my car already come with DOT4, and if not, is there enough of a difference to make it worth flushing my system with it?
Second. If there is a big difference, could I use DOT 5 although it recommends only DOT 3 or 4? Thanks for any help and suggestions.
~Lou
~Lou
