2G 95 FWD Rear Rotor size ?
psi-plz
Jan 2, 2003
Hey guys, i need some help with my rear rotors. i ordered them from tirerack.com (brembo replacement,solid) for my 95 tsi 2wd. when they got here they looked quite big for my car. i just got my front rotors (brembo drilled/vented) and they are smaller in diameter than the rears. also the hole for the hub is smaller on the fronts. i called tirerack and told them this, they said they had sent the right ones, b/c they had the correct part number written down. ok, so my problem is i can't just go look at my car b/c its in storage for the time being. so i need to know for sure that the 2wd has a smaller hub diameter size than the awd. and that the front and rear have the same hub size. this way i can send them back for the correct one, and be certain they sent me the wrongs to begin with. sorry if this is at all confusing. thanks for the help.
here are the facts as I know them ...please correct me if I'm wrong ....
TSI 2wd
front = 10.1" rotor / part number B25365
rear = 10.3" rotor / part number B25557
center bore = 67.06mm
TSI AWD
front = 10.9" rotor / part # B25544
rear = 10.3" rotor / part # B25557
it sounds like you may have gotten the '94 model rotor
'94 Talon 2wd
front = 10.1" part # / B25164
rear = 10.4" part # / B25365
center bore = 67.2mm
the part numbers are for the Brembo OE replacement rotors
what did you get ?????
well the part number on the packing slip is B25164, and same on the rotor box. so according to your numbers i was sent a 1st gen front rotor?? now i'm really confused. but i just measured the center bore on both the front and rear rotors. the fronts come out at 67mm, which is correct. the rears measure about 90mm. is it possible i just have the completely wrong rotor for my car?? thanks for your help Luke.
-PJ
sounds like you have the wrong part ... call customer service and they can fix it for you since, your original sales person hasn't helped
800-428-8355 ext. 362
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
