sschambers
- 143
- 9
- Sep 26, 2007
Hermitage,
Pennsylvania
I started having this problem even before I installed the KYB GR2's w/ Eibach ProKit and ALL of the Energy Suspension bushings. The road noise is so bad, the radio won't even drown it out. (Not too concerned about it at the moment though because the motor is at the machine shop). But the entire suspension is all new, except the wheel bearings - but NONE of them have any play whatsoever. I checked each wheel bearing at least three times.
I'm on stock wheels with directional Wanli 205/55/16 tires, and the tires are fairly new and the wheels were balanced. The road noise is somewhat bad around 25mph, then goes away until around 50-55mph and that's when it's the absolute loudest.
I don't know as much about suspension as I do with motor work, but I have a decent amount of knowledge. Could a wheel bearing still be bad even though none of them have any play?
Thanks for any help.
Steve
Steve
