Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Handling Tech
Handling Tech Suspension, steering, brakes, tires, lightweight wheels, bushings, etc.
Reply
LinkBack Thread Tools
Old 08-12-2008, 08:34 PM   #1 (permalink)
Proven Member
2GturboTALON's Avatar
Region: Midwest
Classifieds Rating: (1)
Reputation: 2GturboTALON is more helpful than not
Did my suspension do this ??? ( Please Look)
So i decided to go out and check my brakes and see if i needed vented or solid rears for my awd talon, while i was out there i decided to check front brake pads and this is what i saw. I'm guessing that maybe the suspension ate away at the inside of the tire. I had noticed a bit of vibration, but thought i just needd brake bad.
Image Hosted by ImageShack.us
Offline
Related Auctions
Sponsored Links
Old 08-12-2008, 09:04 PM   #2 (permalink)
Proven Member
Region: Midwest
I'm on 225/45/17 and not lowered. Also i noticed my front tires were slightly overinflated ( about 41-42 psi, and tires are 44 max) a few weeks back and i deflated them to around 34-36 in the front.
Offline
Old 08-12-2008, 10:46 PM   #3 (permalink)
Proven Member
Region: Pacific Northwest
Classifieds Rating: (3)
Reputation: romeen is extremely helpful and trustworthyromeen is extremely helpful and trustworthyromeen is extremely helpful and trustworthy
Looks like you need to get an alignment. Excessive toe out and too much negative camber can cause that. Inflation pressures of 42 may cause some excessive wear along the midline of the tire but shouldn't cause anything like that.
____________________________
Romeen
Offline
[posts] Reply With Quote
Old 08-12-2008, 11:02 PM   #4 (permalink)
Proven Member
98GSXtreme07's Avatar
Region: Gulf Coast
Classifieds Rating: (0)
Reputation: 98GSXtreme07 is an unknown
Agreed. I bet your over due on a rear-end alignment. I would go ahead and get new tires or just the one if you can't afford it and get a FULL (front and rear) alignment. I had 225/45 before and never had that problem.
Do you have a problem with your rear-end bouncing all over?
-Mike-
98 GSX A/T
98 GSX Totaled
97 GS Sold
Offline
Old 08-12-2008, 11:14 PM   #5 (permalink)
Proven Member
No_Skillz's Avatar
Region: Tri State
Reputation: No_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening to
You shouldn't rub with 225/45/17 on stock suspension. I am running 235x45x17 on lowered suspension and I DD fine.
Your problem lies elsewhere. Either cheap tire or bad alignment.
Quote:
Originally Posted by 98GSXtreme07 View Post
I would go ahead and get new tires or just the one if you can't afford it...
And with AWD, you need ALL 4 TIRES REPLACED AT THE SAME TIME WITH THE SAME MODEL.
| M | i | k | e |
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 08-12-2008, 11:17 PM   #6 (permalink)
Proven Member
Region: Gulf Coast
I did forget to mention that part. Highly Important! Just saying that if money is tight than do the one, BUT ONLY AS A TEMPORARY!
-Mike-
98 GSX A/T
98 GSX Totaled
97 GS Sold
Offline
Old 08-12-2008, 11:29 PM   #7 (permalink)
Proven Member
webconnect's Avatar
Region: Gulf Coast
Reputation: webconnect is an unknown
Thats weird, I had the same exact problem. The tires were not cheap tires at all! However, I just bought some new ones, and the problem hasn't came back. I have been checking the new tires and no sign of unusual wear.
Come to think of it, my rims were bent to hell and warped a little, so I bought some new ones at the same time. Are your rims bent?
EDIT ****
The old rims and expensive tire were from the previous owner. I can't remember the name of the tires, but the tread looked the same. And I'm AWD, and stock suspension, and the damage looks the same! It might be a defect or bad combination of tires for a gsx. Depending if we had the same brand of tire.
Offline
Old 08-13-2008, 02:02 AM   #8 (permalink)
Proven Member
drivemusicnow's Avatar
Region: Midwest
Classifieds Rating: (2)
Reputation: drivemusicnow is extremely helpful and trustworthydrivemusicnow is extremely helpful and trustworthydrivemusicnow is extremely helpful and trustworthy
EDIT ****
NO.
Wear like that is caused by alignment, and alignment only.
As was stated before, it's caused by excessive toe, (positive or negative)
Get that ish fixed and you'll be good to go on your new tires.
Greg
Offline
Old 08-13-2008, 03:47 AM   #9 (permalink)
Proven Member
2point3Tsi's Avatar
Reputation: 2point3Tsi is an unknown
Curious about tire pressure, clearly my door panel states 32 psi up front 29 psi in the rear. Is it supposed to be that high or is it what is recommended for your tire?
Offline
Old 08-13-2008, 07:19 AM   #10 (permalink)
Proven Member
crimsondragon's Avatar
Region: Tri State
Classifieds Rating: (5)
Reputation: crimsondragon is pretty helpful and trustworthy
Are you guys looking at it correctly? What I see is the tire being grinded. It looks like you been bottoming out and grinding that specific part of the tire away with the upper control arm I believe it is and that stud is tearing at the tire as seen by that uplifting.
Tim
My car's name is Grace.
Offline
Old 08-13-2008, 09:41 AM   #11 (permalink)
Proven Member
Quote:
The factory recommended tire pressure is on the low side primarily to provide a more comfortable ride (more flex in sidewall to help absorb bumps) as well as providing a bit more contact patch in the rear for better grip to help prevent oversteer which is harder to control for the average, non-skilled driver.
It's best to experiment with tire pressures to maximize performance since every car will respond differently. Higher inflation pressures (within reason) will make the car more responsive to steering inputs and will also give you better gas mileage but the ride will feel more harsh.
FWIW, through trial and error I've found that 34-36psi on all 4 gives me a good balance of handling and straight line traction. If I was AWD I would probably go a bit higher than that. For best accuracy check tire pressure in the morning before driving (before the tires have heated up).
Quote:
Looking at the third pic I doubt that's the case. I don't see any evidence of rubbing on the upper portion of the steering knuckle (part that attaches to UCA). The tip of the UCA ball joint stud also doesn't show any signs that the tire has been rubbing against it.
Romeen
Offline
Old 08-13-2008, 10:01 AM   #12 (permalink)
Proven Member
Region: Gulf Coast
Reputation: asian312 is more helpful than not
This may not apply to street driving, but if your tracking your DSM, you want to know the 'hot' tire temps as opposed to 'cold' temps. Different tracks will heat each tire differently and getting them to the same operating pressures means leveling them out after a few flying laps. Also different tires will increase and/or decrease temps at different rates, so dialing in a setup is generally car specific. Also due to suspension, driving style, ect.
PS: The tire moves in relation to the inside knuckle and UCA. Therefore a change in position of the suspension does not relocate the tire from either components. About the only rubbing a tire will have will be on the inside sidewall from either improper clearance or flexing of the tire. Not sure if this has been mentioned, but what wheels are these mounted on. Curious if the size/offset has anything to do with this, but my hunch lies with everyone else with the alignment as the culprit.
Offline
Old 08-13-2008, 06:33 PM   #13 (permalink)
Proven Member
Region: Midwest
Honestly, i was thinking the that it was being grinded away just because of the specific part of the tire that gone. IS it possible for the upper control arm could do this?
Offline
Old 08-13-2008, 07:01 PM   #14 (permalink)
Proven Member
kanderson's Avatar
Reputation: kanderson is an unknown
NO, the position of the control arm in relation to the tire does not change when the suspension compresses, as stated above, so there is no way that it could have rubbed on the tire. Excessive toe will cause this symptom, as will negative camber (to a degree). An alignment and new tires are what is needed.
Offline
Old 08-15-2008, 01:46 AM   #15 (permalink)
Proven Member
Evan K.'s Avatar
Region: NorCal
Reputation: Evan K. is an unknown
As stated above it's your alignment, specifically your toe setting. I run a lot of negative camber and don't wear out the inside of the tire because I have a proper toe setting.
-Evan K.
Offline
Old 08-15-2008, 09:51 AM   #16 (permalink)
Proven Member
BoostedinSoFla's Avatar
Region: Southeast
Classifieds Rating: (8)
Reputation: BoostedinSoFla is pretty helpful and trustworthyBoostedinSoFla is pretty helpful and trustworthy
Go get new tires and an alignment. Has nothing to do with your tires rubbing against you control arm.
Ricky -
Offline
Old 08-15-2008, 01:12 PM   #17 (permalink)
mavisky's Avatar
Region: Midwest
Looks like too much toe-out.
Odd wear though since those tire pressures are way too high if they're being taken cold.
-Kyle Mavis
#97 Street Modified Fort Wayne SCCA
Offline
[webpage] [posts] [gallery] [blogs] Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Suspension help g00s3y Newbie Forum 21 01-17-2008 08:48 PM
Is there a difference between the 1g non turbo suspension and turbo suspension? XxEclipseRcrxX Newbie Forum 3 02-17-2006 11:27 AM
suspension ? FullyBuiltDSM Newbie Forum 3 10-29-2005 02:49 PM
Front suspension problem. Suspension makes strange sound... DSMRevolution Problem Diagnosis 0 11-05-2003 09:46 AM
*** suspension *** m_eclipse_96 Newbie Forum 8 01-17-2003 11:07 PM
Page generated in 0.27378702 seconds (81.81% PHP - 18.19% MySQL) with 10 queries
