No Wilwood Kit For 1G's, Info Needed To Bolt One On For Us At $750!!
Car Cannibal
687
164
Jun 7, 2003
Chicago, Illinois
Wilwood already has a bolt on kit for the 2G's for $850 Wilwood 140-8292 - Wilwood DynaPro Big Brake Front Hat Kits - summitracing.com
I have a CNC shop that wants to get into the car industry and will make the adapter plates for pretty cheap so we can bolt it all on.
So, here is the info I need to getting us a complete bolt on kit for around $750 total.
Using a 12.2" and .81 thick rotor, here are the specs I need for the aluminum hat.
Brake Rotor Hat Bolt Circle:
Brake Rotor Hat Offset (in):
Brake Rotor Hat Stud Hole Diameter (in):
Brake Rotor Hat Center Hole I.D. (in):
Aluminum Hats, x2 = $160
Straight Vaned 12.2" .81" Rotors, x2 = $164
Billet Dynalite Caliper 1.75 pist, x2 = $290 ( slightly thinner than Forged Dynalite Caliper )
BP 10 or 20 pads, x2 = $55
Custom Mounting Brackets, x2 = $100
We are looking at $770 ( $730 if you use the Forged Dynalite Caliper ) for a 2 piece rotor, 4 piston caliper, BP 10 or 20 pad, bolt on kit if I can get the info above for the aluminum hat. :thumb:
Got the info I needed from measuring a friends car and the kit will be started on in June.
Looks like the Forged Billet Superlite calipers are the way to go due to the pads and for $850 the 1G's will have a complete 12.2" Wilwood kit. :thumb:
I don't want to rain on your plans here but you do know that I've posted the standard Wilwood DP caliper kit for the 2G will work for this? And we can do better than the price you've posted, including a proper four line hose kit.
But if you choose to move ahead let me know and I'll be happy to quote you prices on the parts you require at a fair price also.
P.M. me what Wilwood parts are in the 1G kit you're calling the basic 2G.
Open up the pdf for the kit. Look on page 2; it's all there.
