fastasleep
- 125
- 2
- Dec 26, 2004
The Burgs,
Virginia
I had a torn passenger front CV boot. I replaced the entire axle. Everything looks good.
I go to test drive the car and all seems fine, right up until I bring the car to a complete stop. I get this noise/vibration in the brake pedal just before coming to a complete stop, combined with a slight studdering/jerking of the car. It's like the power brakes are going in and out just before the car stops.
I know that it's a problem with the front brakes because I can e-brake the car to a stop and it never does it. I don't get this noise/vibration at any other time during the braking process - only right before the car comes to a hault; which, is why I don't think it's a warped rotor or pad not seating correctly. I would think if it were either of those issues, that I would feel it throughout the time that the car is braking; as opposed to this noise/feeling that comes on like a light switch just before I stop.
I went to test drive it again today, and was able to determine that the sound is identical to the sound that you may hear after just starting the car, where you can feel your brakes become 'power' brakes. This sound is the same sound that I get before coming to a complete stop, only accompanied by a jerking of the car and grinding/vibrating feeling in the brake pedal.
I just uninstalled and reinstalled the new axle and didn't come across anything strange. It went smoothly, and everything is back together as it was (and should be). Yet, the problem remains.
Basically, I think I can accurately describe it as: an intermittent loss of power brakes just before coming to a stop.
What would cause this?
