Aftermarket Big Brakes which one for my 1g
high klicks
Jun 16, 2004
vernon,
Hey Guys and Girls looking to buy big brakes which one would you recommend either the ROTORA BRAKES which I'm considering because of the price and if they are just as good as the STOP TECH why not. Those are my two choices that I'm leaning towards are they the same performance any issues that I should consider with either one. Thanks in advance and help is much appreciated.
What are you planning to do with your car? Will it see the track or what? Give a little more info.
What is the purpose of the upgrade? Looks or shorter stopping distance? Or just less fade?
Because your "standard" brake upgrade will be sufficient. As most, such as the ones mentioned above, are over kill. If you really want a shorter stopping distance then tires are more of a limiting factor than brakes. Of course big breaks + good tires = better still. BUT if you are just looking to get rid of fade then just your average run of the mill setup will do just fine. But without doing it correctly you MAY actually lose stopping distance.
