Malero5
- 86
- May 14, 2005
eagle,
Idaho
The line that connect to the top of the PS pump keeps cracking on the metal part. Its the small part of the elbow that goes from the actual bolt fitting to the rubber part of the hose. My last part only lasted about a month. My guess is that the fitting right below is vibrating against it after i removed the Balance shafts. Im just wondering if this is a common problem?
FWD, with a lot of mods and no balance shafts, shitty stock suspension, and lost of wheel hop)
