96Eclipsed
- 64
- Oct 4, 2002
How can I tell if the springs I want to reinstall on my 96 RS are bad? I have a set of Nuespeed springs that were on the car when I bought it. The ride wasn't bad but there was a lot of clanging so when I removed them to go with some coilovers I found that all I had needed to do was replace the rubber insert between the spring and the perch.
Since I had the coilovers I installed them, but have regreted it ever since. Now I want to reinstall the springs on the Illuminas I have now.
The springs look to be in good shape. However I can squeeze the springs a bit, maybe about a centimeter or two. I know that if I were able to squeeze them together easily they're probably bad...
thanks for any help.
