daltah
- 516
- 1
- Sep 27, 2002
phoenix,
Arizona
how do you install a camber kit on a 99 rs elcipse?should i do it myself or take it somwhere?i have a sprint camber kit front and rear but no instructions
Originally posted by siueclipse
you can put them on yourself but only a shop can make sure your camber is correct.. if you havent bought the camber kit yet.. please please please get full replacement parts and not just washers![]()
Originally posted by 2-0turbo
Wrong. You can do your own alignments with nothing more than a flat surface, some tape measures, some nylon string, a builders square and a small ruler. You would be amazed how close I can get. Caster is the only tricky thing to set yourself. It is not adjustable on a stock suspension (1G anyway), so that eliminates that. Using my method, I was only 0.1 degrees off on my camber.
