EclipseTrbo420A
- 3,427
- 39
- Jan 23, 2004
WhiteOak/PGH,
Pennsylvania
Ok, I lowerd my car awhile ago and Just today installed my camber kits( front, rear )which is no big deal because my new suspension has all of 20 miles on it because of winter storage. I got the ebay camber kit that has 1.25-3 inch correction ( positive only ). Well after loweing the car down and taking it around the block It seems as if my front wheels are almost standing straight up if not maybe positive. I havnt had it on level ground to check if it looks too positive or to close to bing positive, but I swear I had more than 1.25 degrees of Negative camber. My question is If, with the added 1.25 degree's my wheels have zero camber then would it be ok to just run the stock arms and have about 1.25 degrees of camber? Im NOT AutoXing now or in the funture so I dont need those kinds of specs I just want a nice street car wiht good tread ware. Ill post some picture I have of this stuff after I get them on the computer. Thanks guys. Any and every suggestions you have, I'll take. Thanks. -
