Dual piston calipers
wastefuldreamer
1,645
6
May 11, 2002
Bloomingburg, New York
I'm looking into getting the dual piston calipers for my car cause i only have the singles. What I wanted to know was. What do i need for the swap? What cars can i get them from? Any help is appreciated.
Gary
try here first http://www.vfaq.com/index-main.html
go to brakes at the top, there are 2 or 3 articles you can probably use.
if you look around on dsmtrader they are often listed as 2 piston or dual piston 1g calipers
i think you need calipers, mounting brackets, pads, rotors, and shims for the pads. maybe new lines. those articles should clear everything up though.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
