dsm-onster
DSM Wiseman
- 8,592
- 130
- Jul 11, 2004
Bloxom,
Virginia
I don't know much about retreads. but is it ok to deflate them to get more traction? or will they screw up, i.e. come apart and kill me at 100mph at the end of the 1/4.
Most if not all areas retreads are illegal to run on the front.dsm-onster said:I don't know much about retreads. but is it ok to deflate them to get more traction? or will they screw up, i.e. come apart and kill me at 100mph at the end of the 1/4.
No, you should not run re-treads on the front period; unless they have some guarantee with them.dsm-onster said:so, to reduce the likelihood of a blowout on the track, i suppose i should inflate the tire to the normal psi, right?
.Bostedquest said:Most if not all areas retreads are illegal to run on the front.
Why? in case they blow out, which they have alot more tendency to do.
khendriksma1 said:That is COMPLETELY untrue. You can legally run retreads on the the front of almost any vehicle. I have worked in the tire industry for over 16 years so don't think what I am telly you is BS.
And if they are legal to run on the street why can't rigs run them on the fronts? It's ILLEGAL, meaning NOT ALLOWED. The driver can lose his license if he is caught doing it. It is a MAJOR safety violation.ndilo21 said:He means illegal at the track, not on the street.
Bostedquest said:And if they are legal to run on the street why can't rigs run them on the fronts? It's ILLEGAL, meaning NOT ALLOWED. The driver can lose his license if he is caught doing it. It is a MAJOR safety violation.
They are not redone like normal tires are made. They have a clear and defined seperation mark, and when it gets too hot, or too dry they fail, where a "normal" tire would not.
1. A garbage truck is not a rig. And as I said RIGS (18 wheelers) CANNOT RUN THEM.khendriksma1 said:You are completely wrong about rigs running them on the front. You would be surprised how many garbage trucks use them on the front. The ONLY law against running retreads on a vehicle is that they are not allowed on the front of passenger buses.
These Green DOT retreads are made using a very similar process to new tires. The main difference that the retreads only involve the remanufacturing the tread area. The equipment used to cure the rubber on the new tire vs. the retreaded tire is very similar.
I could really care less what you use on your car. I just don't like seeing everyone fed with this mis-information.
No, they cost what a wrecked AWD cost. Then you move the parts over. I have seen AWD sheels with full drivetrain/minus engine for under 600. Hell I can get one (but I also need to get trans) for 300. Most people want 3-400 shipped for the trans, so that is 700, well under 3K.dsm-onster said:AWD conversions are costing like $3000 now right?
Bostedquest said:No, they cost what a wrecked AWD cost. Then you move the parts over. I have seen AWD sheels with full drivetrain/minus engine for under 600. Hell I can get one (but I also need to get trans) for 300. Most people want 3-400 shipped for the trans, so that is 700, well under 3K.
Bostedquest said:1. A garbage truck is not a rig. And as I said RIGS (18 wheelers) CANNOT RUN THEM.
2. Retreads are considered Biased tires once retread. If you think they are not read up on the US HDot requirements for retreads. Just like once they are installed, the law requires the vehicle have a tire pressure monitor to warn of impending failures.
3. The info I posted is true.
