Finally installed Pro-Kit and KYB GR2's
Patterson
136
3
Apr 6, 2005
Harrisburg, Pennsylvania
I finally got around to installing my eibach pro-kit springs and new kyb gr2 shocks/struts. Let me just say wow! It is a perfect drop and the car handles great. It absorbs bumps and potholes wonderfully and i couldnt be happier. The installation didn't take too long either. the fronts were a pain but the rear's were easy. I also installed the DIY rear camber kit. that was also easy. I need to install a front camber kit but i'm still shopping around for one. I'll probably end up with the eibach one.
I just wanted to shout out at those confused on what suspension set-up to go after. I am very happy with mine! :dsm:
That is a good daily driver on a budget setup. I essentially have the same set-up on my 1G. Intrax springs with KYB GR-2s. Although the GR-2s are 10% stiffer than stock they aren't considered sport shocks. To me that is fine because I need a somewhat soft ride for daily driving. But the nice drop helps the handling immensely which coupled with the smooth ride makes for a good setup that doesn't break the bank. Add a Road Race rear stress bar to combat understeer and you've got a nicely upgraded but mild mannered DSM.
:rocks: :thumb: :dsm:
Hopefully your GR2's hold up better on your 2g AWD than they did on my 1g AWD with the same setup... the shocks only lasted about 10k
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2G DSM ECU
    $100 picked up 91605 CA $100 + Shipping Need gone don’t have the space for it.
    • Stizzydrew
  • For sale 1g Door cards
    Grey very good condition, pick up only
    • 93 talon tsi awd
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
