2.4 turbo Hyped
- 575
- 3
- Jan 6, 2004
Portland,
Oregon
Ok I recently transitioned from my laser to a stealth. I am trying to put together a suspension package that wont break the bank.
The laser and the stealth suspension appears to be identical (from memory). I need one of you to tell me what size the nut is on top of the front strut and the rear strut pistons.
The stealth has a 19mm nut. I am trying to relate piston sizes.
Reason being is I want to try and put a set of kyb agx's on the stealth and they dont make them for the stealth. I am going to try to use the ones for a t/l/e as the setups appear to be the same.
Anyone that can help out a former dsmer would be greatly appreciated as I shared much abundance of knowledge with others when I was an active member here!
Thanks again for your valuable time tuners!!
