Installing coilovers
richie_gs
Oct 17, 2002
West Des Moines, Iowa
OK i just got some coilovers. Im gonna try to put them on myself, but I dont know how. I know how to pull the strut and everything but the coilovers are in a box and I dont know what parts go where. Like the perches and all the little rings. If any body could help me out or knows where there is pictures that would be cool.
thanks
http://www.griggsracing.com/installation/coil.html
-But yours might be different from the above photo b/c of manufacture, the DDS kit I use require the removal of the front strut weld-on spring perch.
-You must use a spring compressor tool to remove the OEM spring if you plan to reuse the old struts, or take the entire spring/strut assemble to a repair shop to have them remove the spring for you.
