gsxeclipse102
- 558
- 126
- Mar 8, 2003
carmel,
New York
well before going to get an alignment i wanted to make sure i replaced everything that was bad so far. i noticed my car wants to pull to the right a lot but the tires look dead straight (by eye). Well then i noticed my front passesnger side tire is an inch closer to the front bumper then the other side (great
). after closer examining it looks like the control arm isn't in the rear bushing all the way. There is an inch of it not going in compared to the drivers side which has none. My question is do you think the shaft that goes inside the bushing is bent and can't slip in there anymore or the entire arm is bent even though i can't see any cracks or bends in it. (looks identical to driver side). How much do you think an oem replacement arm is and where can i get one without going to mitsu?
car is a 92 eclipse gsx with completely stock suspension.
). after closer examining it looks like the control arm isn't in the rear bushing all the way. There is an inch of it not going in compared to the drivers side which has none. My question is do you think the shaft that goes inside the bushing is bent and can't slip in there anymore or the entire arm is bent even though i can't see any cracks or bends in it. (looks identical to driver side). How much do you think an oem replacement arm is and where can i get one without going to mitsu?car is a 92 eclipse gsx with completely stock suspension.
