bcrosby
- 75
- Jul 11, 2002
What date did the bigger brakes start showing up on the talons?
Just wondering if I have the big brakes or not
Make sure you don't wind up with newer style calipers that use a banjo bolt fitting to attach the brake line unless you have already got custom brake lines made up. I'm not sure but I think the 95+ calipers are all the newer style. I used the calipers off a '92 Diamante just to make sure I got the older style threaded fitting.Originally posted by jrw
I am upgrading my single piston to the dual pistion off a 95+ to my 1g NON ABS car.
