Turbo Smurf
- Mar 26, 2004
Staunton,
Virginia
Here is my relevant info for this post:
-'95 TSi AWD, manual trans.
-Tokico Illumina spring/shock kit. Drop is ~2inches.
-All suspension bushings replaced with Prothane, so no seized joints (anymore).
-17x7" wheels, 40mm offset. 225/45R17 tires.
I just got a 4 wheel alignment and we were able to zero the toe on the front suspension and get the front/rear cambers in good form. However, even with new rear toe adjustment eccentric bolts, we were not able to get the rear wheels within spec. Not enough adjustment.
From memory, my specs were:
front camber ~-1.3 deg (both sides), zero toe.
rear camber ~-1.7 deg rear (both sides), -.81 toe each side (negative means toe out). This is around 7/16" total toe out, which is not good.
So how to fix this?
1.) If I increase the rear camber (more negative), it looks like toe would improve (less out). I can easily do this by removing washers from the UCA, but I like the camber where it is and would prefer not to increase it.
2.) It looks like increasing the rear ride height would give me less negative toe. I could do this by adding a shim under the strut or in the strut, above the spring. Shimming above the strut would require me to knock out the studs in the top of the strut and weld in longer bolts. Shimming in the strut would cause me to lose some suspension travel in extension.
3.) Lengthening the rear toe control arm or getting an adjustable control arm would be ideal. Anyone know if someone makes one? Something with HEIM joints and a built-in adjustment would be great. I have looked around and have only found the 1G kits from Taboo where you hack up the stock piece.
Any ideas would be greatly appreciated. Thanks in advance!
So how to fix this?
