Guys please help i have a few questions
screamineagle97
Aug 23, 2002
1) I just purchased new tires and rims...Enkei RS6 17x7 and Kumho Ecsta Supra 712's 215/45/17 is this setup ok for a 97 talon and are the Kumho's good tires?
2) I want to lower the car next but i need some suggestions on weather i should go with coilovers or just go with lowering springs....I'm thinking of going with the Eibach Pro Kit is this a good lowering spring and does anyone know where i can get a good price on the net or anywhere else?
3) I also need new brakes and rotors is there any benefit to changing the stock O.E.M rotors to slotted/cross drilled rotors....and do any of you know of good brake pads to reduce the brake dust on my new rims.....a friend of mine told me to go with metallic brake pads they don't give off any brake dust is this true?
Any help would be greatly appreciated....thank you so much for any help you can give to me
Well I can offer you some info on this. My Brother in Law has those tires on his Avenger and he is very satisfied. He can take corners extremely sharp without squealing. I have the Nitto NT-450s and I am disapointed. I've had a bubble in one, one pop, and I think that they have a tendency to squeal. I plan on going with the Kumho Escta for my next set of rubber.
1) Yup
2) Eibach
3) Hit up the old "search" function, it'll tell you a lot. Also, hit up the newbie section as well.
best price i found was here.. have to call them but no big deal..
http://www.no-limit-enterprises.com/
210 bucks for the pro-kit not bad not bad
