ABS conversion
jim97gst
482
3
Aug 2, 2002
Bethel Park, Pennsylvania
I was told that all I need to do an ABS conversion is the ECU from an ABS car and the ABS control box. Does anybody think this conversion is worth the money and time?
I used to be against ABS because I thought of it as less control over the car. A recent article in Sport Compact Car (the most recent Ultimate Street Car Challange) swayed my opinion.
I participate regularly in SCCA autocross.
What would be a resonable amount of money to pay for an ABS ecu and control box.
Any opinions appreciated. Thanks.
I got kinda excited when I saw there was a reply to the post. Then a little disappointed when I saw it was you commenting that no one had replied. At least you moved it to the top of the list.
You're right. There aren't a lot of people interested in turning or stopping the car. At least not nearly as many as there are who want to go fast in a straight line.
I posted a similar thread a while back and got hardly any responses. I miss ABS and want it on my DSM. I am still cirsing myself for not getting it as an option. Try your local Mitsubishi dealer, they might be able to give you a good idea.
Well I dont think It's worth doing the conversion. I never found it useful in my driving. maybe because I dont slam on the brake. the only time it probably came in useful for me is when It was raining an I had to make a sudden stop. my tires where smooth so I slid anyway(I was a foot away from the other car).
I think I heard you talkin about autocross sometime. I dont know much about that. but If you to like swing/loosen the back end a lil so you can make those tight corners, wouldn't ABS not allow that?
-That simple? There's running of tube, brake modulator, a bunch of wires to run, speed sensors at each wheel, ...and the G sensor.
it is alot of work, it is almost to the point where it would be easier to get another car that has abs.
