Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > Community > Regional DSM Clubs > Gulf Coast DSM Forum
Gulf Coast DSM Forum Texas, Louisiana, Mississippi, Alabama, ect.
Gulf Coast Region Homepage
Reply
LinkBack Thread Tools
Old 07-24-2008, 02:40 PM   #1 (permalink)
Proven Member
DSM_PWR's Avatar
Region: Gulf Coast
Classifieds Rating: (10)
Reputation: DSM_PWR is an unknown
Recommended Performance Shop For Diagnosis in Austin/San Antonio
As many of you may know, my car's been having stuttering problems that feel like a boost leak/fuel cut around 5k RPM. It’s been that way for the past 3months now and I’ve just about checked as many things as I can to where I’m FINALLY tired and stumped! So I decided to take it to a shop and have them fix the problem.
I’m penciled in at ProTech here in Austin for the middle of August but id really prefer taking it anywhere else if someone can recommended me a good shop that will do the job right and in a timely manner.
Thanks
Richard
Offline
[posts] [gallery] [blogs] Reply With Quote
Related Auctions
Sponsored Links
Old 07-24-2008, 05:47 PM   #2 (permalink)
New Member/Lurker
carslinger's Avatar
Region: Gulf Coast
Classifieds Rating: (0)
Reputation: carslinger is an unknown
Thanks
Richard
Your car sucks....light it on fire...!!!
or ....TAKE IT TO MZM!
Offline
[posts] Reply With Quote
Old 07-24-2008, 07:14 PM   #3 (permalink)
Proven Member
boostedt28's Avatar
Region: Gulf Coast
Reputation: boostedt28 is an unknown
Thanks
Richard
DO NOT take your car to ProTech for that type of work. If you want, call Colvin Automotive and ask to talk to Daniel. He used to have a pretty quick 20g equipped 2g. I'm not sure of his duties there (if he is still there) but he should be able to help you if he is.
Offline
Old 07-24-2008, 08:20 PM   #4 (permalink)
Proven Member
DSM_PWR's Avatar
Region: Gulf Coast
i think i need baby jesus ...
I called MZM a while back but they just keep pushing back the date and dont return calls.
Ill give Colvin's a call tommorrow and ask..
Offline
Old 07-24-2008, 08:21 PM   #5 (permalink)
Proven Member
1stGenTSi's Avatar
Region: Gulf Coast
Reputation: 1stGenTSi is more helpful than not
Whats it feel like when you get to 5k rpm at WOT? Is it like hitting a wall or just a significant decrease in power? Do you have anything other than SAFC/maf-t to control fuel? What happens to timing? You could be getting a lot of knock due to lots of negative correction on the afc. Got a log of what happens? Did this problem occur on the 16g you had before?
Offline
Old 07-24-2008, 09:13 PM   #6 (permalink)
Proven Member
hdoerr's Avatar
Timeslip: 15.158 @ 92.190
Region: Gulf Coast
Reputation: hdoerr is an unknown
He ran a T25 before this 50 trim.
Offline
Old 07-24-2008, 10:45 PM   #7 (permalink)
Proven Member
DSM_PWR's Avatar
Region: Gulf Coast
Quote:
Heres the thread where i expalin it all:
fuel cut I have no idea whats wrong. help
But just in case...
I installed my 50trim and was running perfectly fine for about 2-3months. Tuned 11:1, w/ a little mix of e85 at 24psi with no knock/timing being pulled.
One day it just magically started happening..
Started stuttering so i lowered boost to 19psi, ran like that fine for a while then started to sputter as well, went down to 17psi, then 15psi and now
Around 4500RPM at 15psi, the car stutters/feels like i hit a brick wall. Then builds boost again and stutters again at 15psi.
The car is tuned 11:1-11:5 but still stutters at 4500RPM.
Timing takes a dip in the early RPMs which is normal and reaches around 9deg at 4000-4500rpm, seems to be climing at a decent rate
My Fuel trims are dead on, and cruise (mid) doesnt seem to have any kind of effect.
Heres a short list of what ive tried:
*Boost leak tests
*Swapped ECU
*Swapped Battery
*Swapped Coil packs
*New Spark Plugs (gapped .26)
*New Spark plug wires
*New PCV
*Removed Emissions with a EGR Block off plate
*New MBC (although i went from a cheap ebay to a homemade one that worked on a friends car)
*Lowered the boost to 17psi and tried it with 560cc injectors
*Tried 3 different Gm MAF
*Swapped the leaky Greddy Type S BOV for a Tial BOV
The funny thing is, when i reset the SAFC to start the tune over from scratch (started back at zero across the board) i did a pull and it held 15psi fine to redline, however, it was pretty lean since i did a pull with it zero'd out.
Offline
Old 07-25-2008, 03:44 AM   #8 (permalink)
Proven Member
hdoerr's Avatar
Region: Gulf Coast
Fuel Pump?
Offline
Old 07-25-2008, 06:53 AM   #9 (permalink)
New Member/Lurker
Region: Gulf Coast
Reputation: c_king333 is an unknown
What kind of spark plugs are you using?
____________________________
CHRIS
Offline
Old 07-25-2008, 08:08 AM   #10 (permalink)
Proven Member
DSM_PWR's Avatar
Region: Gulf Coast
Quote:
Originally Posted by hdoerr View Post
Fuel Pump?
A Supra Fuel pump is on its way that i ordered just in case
Quote:
NGK BPR7ES
Offline
Old 07-25-2008, 06:03 PM   #11 (permalink)
New Member/Lurker
98spyderturbo's Avatar
Region: Gulf Coast
Reputation: 98spyderturbo is an unknown
Precision R
San Antonio Tx
Great group of guys. Mostly evo guys that work there. Pretty sure they can do it.
Offline
Old 07-25-2008, 07:33 PM   #12 (permalink)
New Member/Lurker
Region: Gulf Coast
Did this problem start when you installed the maft?
CHRIS
Offline
Old 07-26-2008, 06:34 PM   #13 (permalink)
New Member/Lurker
Region: Gulf Coast
It looks like you figured out your problem in the other thread. You need dsm link or just go all out and get aem.
CHRIS
Offline
Old 07-26-2008, 06:48 PM   #14 (permalink)
Proven Member
DSM_PWR's Avatar
Region: Gulf Coast
well i dont wanna say ive figured out the problem till its fixed because i must have thought i figured it out at least 15 times now... so untill i can redline 24psi again w/ no problem, then ill be happy
Offline
Old 07-26-2008, 11:46 PM   #15 (permalink)
New Member/Lurker
Region: Gulf Coast
It sounds like its all in your tune.
CHRIS
Offline
Old 11-10-2008, 11:02 AM   #16 (permalink)
New Member/Lurker
Region: Gulf Coast
Reputation: BrentCRX is an unknown
F.I.S.T.
(832) 775-0981
Oh and my money is on your tune being bad.
Offline
Old 11-10-2008, 11:12 AM   #17 (permalink)
Proven Member
DSM_PWR's Avatar
Region: Gulf Coast
Quote:
Originally Posted by BrentCRX View Post
F.I.S.T.
(832) 775-0981
You owe me some money then...
wow this thread takes me back
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Clutch Install Shop-San Antonio ewoevo Gulf Coast DSM Forum 16 07-04-2008 12:16 AM
need help.my San Antonio and Austin .... tsi4ya Gulf Coast DSM Forum 4 04-24-2008 06:42 AM
san antonio shop lightingMcQ Gulf Coast DSM Forum 1 04-01-2008 06:59 AM
Shop in San Antonio that can rethread? Jdiddy2k4 Gulf Coast DSM Forum 2 03-19-2008 06:08 AM
Import Face-off In San Antonio Feb 6 At San Antonio Raceway GSX-MAN-IN-TX Gulf Coast DSM Forum 8 02-07-2005 03:08 PM
Page generated in 0.23860693 seconds (85.97% PHP - 14.03% MySQL) with 10 queries
