Beechnut
- 45
- Oct 24, 2011
West branch,
Michigan
I have a 6 bolt that came out of my 93awd talon reason I'm selling is don't need it and putting my 2.3 stroker 7bolt instead. So like mentioned earlier no need for it. Can go to a good home.
Motor-
30K after rebuild
Acl aluaglide main and rod bearings
Standard bore stock 6bolt pistons and rods
Felpro gasket set for the rebuild including head gasket.
Compression are as follows
#1-175
#2-175
#3-172
#4-175
Beautiful running motor ran upuntill I pulled it out tonight.
Always ran stock boost no more.
Everything is included except exhaust manni intake manny and of course the turbo. Other than that consider it a long block. Oil pan to valve cover.
$600.
Pretty firm.
Also have a lot of parts for 1g dsm's just ask I ###### have it laying around.
Can text if its easier for you
9897018205
Sent from my Galaxy S III using Tapatalk 2
Motor-
30K after rebuild
#1-175
#2-175
#3-172
#4-175
$600.
Pretty firm.
9897018205
