complete stock 1G 1990 laser rs turbo for sale
dsmlaser10
Dec 3, 2011
brownstown, Michigan
I have a running complete stock and very clean 1st gen for sale. its a 1990 plymouth laser rs turbo that is in super clean condition and is all stock. it has a brand new clutch kit in it, brand new alternator, lower half of the engine has been redone so it fires right up every time. it has redone exhaust with aftermarket muffler. IT DOES NEED WORK: flywheel needs to be resurfaced or replaced, it needs ngk spark plugs and wires, it does burn some oil because the valve seals need to be redone also it has a small oil leak the oil filter housing gasket needs to be replaced. starting price is $1950 if your interested or have questions you can reply to post or email me at [email protected]
alright cool, when i got it i put new plugs and wires in but i didnt put ngk plugs and wires in i didnt know that the only kind of plugs you can use are ngk coppers so the ones in it now cause it to run sorta rough. and obviously since the flywheel needs resurface or replace its not grabbing fully at times through out every gear or in other words it doesnt accelerate as fast as it should. but the clutch kit in it has less than 30 miles on it i changed the alternator at the same time so its brand new, body has very minimal rust just two spots and they are right next to each other, theres like a dime sized paint chip on the hood the rest of the body is great. interior is like 9 out of 10. underbody is even in great condition.
