Uknown part?
zise ex
Proven Member
72
Dec 1, 2012
martinsville, Indiana
i just discovered that this is the multiport fuel injection relay. how do i find out if this relay is bad?
this morning i pulled out my stock ecu to plug in my ecu with dsm link... the case was already loose on the relay from what i could see after i pulled it out. you can see in the first picture where the coil had contact with the case and caused it to ark weld... after that when i plugged the relay in my car wouldnt attempt to turn over at all... ill be able to test it tonight or tomorrow but i would think that when it hit the case and then my car would not do anything after, that the relay may be bad.
