Devin LeBlanc
- Dec 27, 2012
Las Vegas,
Nevada
Hey Guys, Thought I'd introduce my self and get a build thread going. Im 21 years old and work in the performance automotive field out here in vegas. I was lucky enough to get a job doing what I do and I love every day of it. About a month ago I picked up a 1998 GSX with 130k on it all stock. I got it for a decent price and had plans for it before I even bought it. My goals with this car is about 500whp with quick spool and nice street drivability and a 125 mph trap speed goal in the 1/4. I have started to gather some parts and start the build process. I plan on bringing the car to Texas for TX2k13 just to have some fun and hang out with the great crowd the texas meet brings. I have background in building 4g63's for evo's from basic upgraded bolt on cars to fully built 700+HP 4g63's. I have also had a lot of tuning experience with ECU flash and tephramod v7 ect tuning evo's and STI's alike.
I am excited to put this car together and make it a fun car to drive around and run at the track. Here is a current parts list I have waiting to be put on the car. I have mostly everything other than little odd's and ends.
Brian Crower Single Spring/Titanium Retainers
Crower 280 cams
AEM Cam Gears
2006 Evo 9 Lifters/Rocker arms
ARP Head Studs
Cometic Head Gasket
ACL Race Bearings (Main/Rod/Thrust)
OEM Mitsu Piston Rings
2006 Evo 9 OEM Pistons
2006 Evo 9 OEM Rods
ARP Rod Bolts
2006 Evo 9 OEM Crankshaft
OEM mitsu Oil Pump
GMB Water Pump
OEM Mitsu Timing Belt
OEM Mitsu B/S Belt
NSK Timing Idlers
OEM Timing belt tensioner
New OEM Oil pan
RC Engineering 1200CC Injectors
Deatschwerks 300lph Intank Pump
XTD Extreme PP 6 puck unsprung disc
XTD Chromoly flywheel
GT3582R .63 T3 (Trying to keep the spool quick)
Tial 38mm MVS Wastegate
Hallman Manual boost controller
Ebay T3 Manifold, modifed for tial Vband
Omni 4 Bar Map sensor/GM AIT sensor
Evo 8 ECU on Speed Density via Tephramod v7
3.5" core Bar/Plate Intercooler
Here are a few pics of the car as it sits, I am planning to start tearing into it next week sometime to get the block and head apart to start the machine work on it.
Hope to be updating soon!
Thanks,
Devin LeBlanc
Crower 280 cams
AEM Cam Gears
ARP Head Studs
Cometic Head Gasket
2006 Evo 9 OEM Rods
ARP Rod Bolts
OEM mitsu Oil Pump
GMB Water Pump
OEM Mitsu B/S Belt
NSK Timing Idlers
New OEM Oil pan
Thanks,
Devin LeBlanc
at laggy turbo!
