94 Galant ES build (pics heavy)
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
The car has been through many changes, and I have taken pictures of everything. It is my daily driver and my project, and it is really hard to modify it this way .For some it may be annoying, for some it may be fun. I hope you enjoy it!
This is how my car looked when I first took it home back in 2006/winter/ - just another galant on the street. That didn't work out for me very well; having experience in painting and detailing cars, some basic knowledge of mechanics I can proudly say that my car hasn't been in shop for any repairs. So here we go:
Originally the car was automatic
First mod - sway bar out of 2g GST /15mm/. The car didnt have one to start with.
Second mod - rear disc swap, dual piston front calipers off 2G GSX, and 5 lug conversion to all four corners
After some painting she looked like this
New exhaust: 1g Eclipse Tsudo SS header, 3'' Magnaflow cat and 3'' Ebay GST catback.
Replaced the GST sway bar with 3g Eclipse 18mm sway bar and tubular lower and upper control arms.
Went and bought 2g KYB AGX and Eibach Pro kit
On December 7th, 2008, I finished the 5spd swap and installed 2g leather steering wheel which was a bolt on BTW. All parts besides the trans came out of 2g GST
I was collecting turbo parts, and in the meanwhile I did some custom work.
work in progress
My engine bay in late 08
cleaned up - went with the back theme
More goodies
4 - point Ralliart under brace
And yes the car was stripped for another paint job
Sometime in the spring of 09, I went turbo. Tuned with MAFT and SAFC on 510cc Evo3 injectors. The setup was s16g, Bullseye hotside, Evo3 manifold and o2 housing, 3'' Ebay DP, Adjustable FPR.
updated
Got me 02 Infinity g20 side skirts, Integra Mugen lip (LOL) and 09 Lancer GTS rims
More parts came in - 2.4L Wisecos, Eagle rods, ACL bearings, Evo3 oil filter housing, Sonata 43cc head, Evo3 intake manifold
The OEM 2.4L Cam gears
Did thge rear Evo brakes
Another set of wheels
In January 2010 I pulled this out.
The shit is so dirty and sludgy its not even funny
The head isnt looking right
Trans is ok, no play at the shaft, im gonna replace the pivot ball and the throw out bearing
Well, I happened to find out that I was driving w/o balance shaft belt for the past 3 years
More Shats, Im gonna leave the pics do the talking!
All cleaned up
Balanced and assembled!
Everything is in!
And While I was ding the engine, my friend did this
Finally home after a month of headaches and curses.
Some JDM stuff
A few engine shots
Started a little project here:
before
And after
Dropped 1k on this.
My new setup
Finally some progress on the from Brembos. I used KMV brackets
Newest pictures:
From East Coast MOD
My car is spitting antifreeze ..LOL
Finally done!!! Moar braking powa'! Daym, its been a while since I bought these!
I found out that my curved control arms have bad ball joints after just 3 1/2 years. WTF??!! I need to buy new ones again!
Im having some 4Loko and relaxin ### it has been a very loooong day for me.
Very good looking gallant i was a bit skeptical when I first started looking at this but this is a great build great to see it I love these gallants.
Looks great man, want to do an evo2 clone but not practical at the moment
keep this thing updated
I have to say one of the best Galants Ive seen in jersey ... Thats not all pep boyed out !!!! LOL
My car was in two accidents that I know of, and the last one was with a deer. Half of the roof was smashed in. I repaired as much as I was able to, but the chassis started cracking windshields - its on the 5th windshield.
Either way, I just picked up one of the rarest Galants in the US. Its a 94 Galant GS. The 94 GS takes second place of rare Galants after 91 Galant GSX. The GS was made only in 94 and only 1700 of them were made.
Here are some pics
Everything from the red one will be transferred over to this one plus AWD swap.
A few last shots of the red Galant
Its a mess!
Pass side rust spot
Driver's side rust spot
I refuse to half-ass it! Do it once and do it right!
All the shit that came out from under the car
Test fitted the AWD tank to see which holes to use for the AWD tank straps
Driver side rear hole
Dr. side front hole
Pass side rear hole
Pass side front hole
Dropped the bolts in
Rear subframe
The advantage of having your own powder coating system. Thats my new short shifter (home made type of deal) and some of the rear subframe bolts
The rear carrier
The front carrier - its pretty trimmed so it fits there.
What do you think - its about 6'' short?
My quick trans installation
What Galant forum do you frequent?
Thanks for the comments guys! I appreciate it.
Yes, I got it from a guy in PA.
Installed the spare 4g63 engine I have.
Eclipsh suggested that I cut the drive shaft in the middle, so there it goes
I used some exhaust pipes and t-bolt clamps to get the shaft to its correct length. I'll be taking it to the drive shaft shop this coming week
Full drive shaft installed.
This is the piece that can be fit in the Galant's tunnel. I had to fab up a housing for it to make it beefier.
from this
to this
Filling the gaps
Carrier bearing tacked in its place.
Been sick for a couple of days and havent been at the garage.
I did the roll stoppers with liquid urethane and its not the Windo weld urethane or any home depot roofing urethane, but the very same that the motor mount inserts are made of.
I had the partial insert in the rear one and full race welded front one which actually was kind of harsh.
If anyone cares, this is what I used:
dSt DIYMMI Do It Yourself Motor Mount Inserts - Liquid Urethane
Everything is coming off tomorrow and I'll be coating the undercarriage.
Just a quick few pictures of all brackets, bolts, nuts and washers being coated.
