69_luv
- 522
- 9
- Nov 3, 2003
Jacksonville,
Florida
I have a 95 GS-T automatic trans that has two broken mounts on the casing, the front lower hole is completely gone, and the rear mount has a bolt studd broke completely off the trans.
I have a 98 GS-T auto trans that has level 10 components, and valve bodies, but I have found that there is a really big difference between the 95 and 98. What I want to know is this:
Can I take the internals, the rebuild kit, clutches, level 10 components, or anything out of the 98 automatic and put it into a new 95 casing? Are the components from a 98 at all interchangalbe into a 95 casing? I am posting a picture of the 95 and 98 and you can see that they are no where even close to the same transmissions. Thanks guys for all the help. Please only answer this if you are sure that these parts are interchangable, and if anything can be salvaged from either trans to make a new trans work.
