dklue
- Jan 3, 2004
Farley,
Iowa
I am in the process of removing my transmission on a 94 eclipse fwd,
I have the half shafts knocked out of the hub and the steering rod off,
what is the next procedure ? I cant get the half shaft out of the hub,
do you have to remove the hub from the lower ball joint, and if so, do
you have to cage the strut from flying apart, or will it stay together ?
Can you take the hub off the lower ball joint and just swing the hub
out to get the half shaft out? Or do you pry it out of the transaxle at this point ? Thanks in advance.
Dave
Dave
(awd axle)
