1PhAtGsT
- Feb 2, 2003
milwaukee,
Wisconsin
I have a 1990 gst and ive replaced the slave cylinder, the clutch master cylinder, blead the lines adjusted the clutch master cylinder all the way out and even put the extension rod on the slave cylinder and you have to press the clutch all the way to the floor to shift gears i also put a new act 2100 clutch in and had the flywheel machined down do you think they could of machined it too thin???
thanks for the info
thanks for the info
