AWD
- 46
- Aug 28, 2002
Is there a affermarket, or even a stock clutch master cylinder to replace the piece of crap that's on there now. I've rebuilt my master cylinder 4 (did slave every other time) and replaced both once. I have a act 2600, and all my clutch lines are stock but do not leak, nor do they buldge. What does John Shepard use? Even after I repalce or rebuild it still needs to be pushed 7/8s' of the way to the floor. If I adjust it higher, fluid pushes around the back of the seal. I'm at the end of the bolt and I lifted the carpet right now and the clutch still grabs but does not leak.
