Turbo 2g awd
- 58
- Jan 26, 2003
I got the Taboo clutch Fork when I did my Tranny, ACT 2600, and ACT Flywheel. I put it all together and then had to take it all apart again cause the clutch fork was grinding against the pressure plate. I installed everything the right way. I had to take it back out and grind it down so it would clear the pressure plate. After a day wasted pulling the tranny again I got it fixed. Just wanted to know if this happend to anyone else. I also sent Taboo an e-mail about this to try to see what happened.
I hope you didn't put that back on the car?! Clearly you've changed the material properties in that fork in a critical area. I speculate if you are running a high clamp force clutch, the fork will fatigue over time and potentially fail or add unneeded flex causing engagement issues.
We all know how extremely touchy the DSM clutches are, one shims the pivot ball 1mm too much - and the fingers of the pressure plate start hitting the springs of the clutch disc. 1mm too little - and the clutch won't disengage. There's just way too many variables - such as the manufacturing tolerances of the components (= the block, crank, flywheel, clutch disc, pressure plate, fork, pivot ball and bellhouing) and their wear, that literally every clutch setup becomes an individual affair - and one has to drop the tranny even five times - in order to make the ACT2600 work the way it's supposed to (at least I do). It's time consuming, labor intensive and can be very frustrating, but correctly disengaging clutch will save the synchros of the tranny and the components of the hydraulic system in the long run.
ya...i am puting my car back together after i got back what was left of it from being stolen. I plan on usning a few thing including their shift fork. I would REALY like to use those tail lights they have, but nothing yet....same with the hood
